Low Brake Fluid Level Warning Light
If this light comes on and stays on while you are driving, slow down and pull off the road. Then stop the vehicle carefully. There may be a problem somewhere in the brake system. Check the fluid level of the see-through reservior.
If the brake fluid level is low...
At a safe place, test your brakes bt starting and stopping.
o If you judge that the brakes still work adequately, drive cautiously to your nearest dealer or shop for repairs.
o If the brakes are not working, have the vehicle towed in for repairs.
CAUTION: Continued normal driving with low brake fluid level is dangerous.
If the brake fluid level is correct...
Have the warning system checked by your Toyota dealer.
Spoed gezocht: remklauwen rondom 1992 n/a SW20
- Surferdude
[url=http://www.flickr.com/photos/arthur_mol ... /:w5rnltst][b:w5rnltst]flick[/b:w5rnltst][b:w5rnltst]r[/b:w5rnltst][/url:w5rnltst][/align:w5rnltst]
[img:w5rnltst]http://farm4.staticflickr.com/3069/1303 ... 67c5_n.jpg[/img:w5rnltst][/align:w5rnltst]
