Wat betekenen de lampjes op mijn dashboard?
Omdat niet iedereen het serviceboekje of de handleiding van z'n MR2 heeft hieronder een verklaring van de lampjes van het dashboard: KLIK! of kijk hieronder:
MR2 Mk2 Warning Lights
by Paul Walker
This information is taken from the Toyota MR2 Handbook supplied with a 1994 Mk2 MR2
Image Parking Brake Reminder Light
If this light is on, make sure the parking brake is fully released. The light should go off.
Image Low Brake Fluid Level Warning Light
If this light comes on and stays on while you are driving, slow down and pull off the road. Then stop the vehicle carefully. There may be a problem somewhere in the brake system. Check the fluid level of the see-through reservior.
If the brake fluid level is low...
At a safe place, test your brakes bt starting and stopping.
o If you judge that the brakes still work adequately, drive cautiously to your nearest dealer or shop for repairs.
o If the brakes are not working, have the vehicle towed in for repairs.
CAUTION: Continued normal driving with low brake fluid level is dangerous.
If the brake fluid level is correct...
Have the warning system checked by your Toyota dealer.
Image Discharge Warning Light
This light warns that the battery is being discharged.
If it comes on while you are driving, there is a problem somewhere in the charging system.
The engine ignition will continue to operate, however, until the battery is discharged. Turn off the air conditioning, blower, radio, etc. and drive directly to the nearest Toyota dealer or repair shop.
Image Low Oil Pressure Warning Light
This light warns that the engine oil pressure is too low.
If it flickers or stays on while you are driving, pull off the road to a safe place and stop the engine immediately. Call a Toyota dealer or qualified repair shop for assistance.
The light may occasionally flicker when the engine is idling or it may come on briefly after a hard stop. There is no cause for concern if it then goes out when the engine is accelerated slightly.
The light may come on when the oil level is extremely low. It is not designed to indicate low oil level, and the oil level must be checked using the level dipstick.
NOTICE:
Do not drive the vehicle with the warning light on - even for one block - until the cause is fixed. It may ruin your engine.
Image Low Engine Oil Level Warning Light
The light warns that the engine oil level is low. Add oil as soon as possible
NOTICE:
Continued driving with low engine oil will cause the engine to be damaged.
Image Mailfunction Indicator Lamp
This lamp warns that there is a problem somewhere in your engine electical system.
If it comes on while you are driving, have your vehicle checked/repaired by your Toyota dealer as soon as possible.
Image "ABS" Warning Light
This light warns that there is a problem somewhere in your anti-lock brake system. When the "ABS" warning light is on (and the brake system warning light is off), the brake system operates conventionally but without anti-lock function.
If it comes on while you are driving, have your vehicle checked by your Toyota dealer as soon as possible.
Image Open Door Warning Light
This light remains on until all the side doors are completely closed
Image Engine Compartment Cooling Fan Warning Light
This light warns that there is a problem somewhere in the engine compartment cooling fan system.
If this light comes on while you are driving, slow down and take your vehicle to the nearest Toyota dealer or qualified repair shop for a repair.
NOTICE:
Do not drive over 37mph with the light on
Image Power Steering System Warning Light
This light warns that there is a problem in your power steering system.
If the light comes on while you are driving, have your vehicle checked by your Toyota dealer as soon as possible.
CHECKING SERVICE REMINDER INDICATORS (except the low fuel level warning light)
1. Apply the parking brake
2. Open one of the doors. The open door warning light should come on
3. Close the door. The open door warning light should go off
4. Turn the ignition key to "ON", but do not start the engine. All the service reminder indicators except the low brake fluid level warning light and open door warning light should come on. The "ABS" warning light goes off after 3 seconds.
5. Turn the key to "START". The low brake fluid level warning light should come on.
If any service reminder indicator or warning buzzer does not function as described above, either the bulb is burned out or the circuit is in need of repair. Have it checked by your Toyota dealer as soon as possible.
Thijs van wijk wrote:Maarja... Welk is nou welk! Ik mis voorbeeld icoontjes! ;)
Wel bijzonder handig!
dubbeledraaideur wrote:Nieuwe link:
http://www.imoc.co.uk/technical/faq/war ... lights.htm
En hersteld, bedankt voor de melding. :dux-blij_thumb-up:
crasywheelyboy
bij mij gaat het Low Brake Fluid Level Warning Light branden alleen bij eek oude motor bij een warme motor tussen de 2000 en 3000 toeren en als ik de bochten door ga
olie pijl is goed
remvloeistof pijl is goed
iemand....?
Freddie63
Even de Accu eraf leggen voor een nacht...
hierbij reset je de boardcomputer en kun je zien of het een significant probleem betreft of dat het lampje gewoon weer uit gaat
