uitlezen ECU AW11
Posted: 22 Nov 2007, 13:43
ik zie vaker stukjes over het uitlezen van een MK2ECU, maar niet van de MK1, dus hierbij voor degene die dat zoeken.
bron: http://www.challoner.com/mr2/tech/diagnostics.html
Toyota MR2 Mark 1 ECU Diagnostic Codes
Introduction
Most of this information is taken from the Toyota engine repair manual for the 4A-GE engine fitted to normally aspirated Mk1 MR2s.
The ECU (Electronic Control Unit) contains a self-diagnosis system which detects malfunctions and abnormalities with the engine electrical systems. These could be present in the wiring, the sender unit (e.g. throttle position sender or distributor), in the ECU itself, or any combination of those three things. Therefore it can be quite a complex process to identify and rectify the fault. Don't let that put you off checking these things for yourself though - you may be able to find the fault and fix it easily! Even if not, you'll have a better idea of what is wrong which may help if you then take the car to a garage or dealer for repair.
Check Engine Warning Light
If the ECU detects a problem it indicates this by keeping the check engine warning light illuminated when the engine is running. See my page on instrument panel warning lights to identify the check engine warning light. It may be the case that the engine stops and will not restart if you have one of these problems, which means you won't be able to check if the check engine warning light illuminates when the engine is running! If this is the case you may wish to follow the steps below anyway to see if you have any electrical system problems.
Output of Diagnostic Codes
The ECU can flash the check engine electrical system warning light a certain number of times for each error it has stored. To make the ECU do so you need to short two terminals in the diagnostics terminal. The latter is easily accessible at the rear of the engine bay, and it can be seen in the photos on my JR air filter installation page. The warning light will flash the number of times equal to the error code with a 2.5 second pause between each error code and a 4.5 second pause before starting the sequence again. For example, if you have error conditions 3 and 5 you would see the following on the check engine warning light when you short the two diagnostic connector terminals:
3 flashes - 2.5 second pause - 5 flashes - 4.5 second pause - 3 flashes - 2.5 second pause - 5 flashes - 4.5 second pause...If you have just error code 6 then you will see:
6 flashes - 4.5 second pause - 6 flashes - 4.5 second pause... The full procedure for obtain the error codes is as follows:
Diagnostic Codes
The following table lists details of the diagnostic codes.
CodeSystemDiagnosisTrouble Area1NormalThere are no problems.None.
2Pressure sensor signalOpen or short circuit in pressure sensor.
After repair of the troubled area, the diagnostic code(s) retained in memory by the ECU can be cleared by disconnecting the battery or removing the 7.5A AM2 fuse in the main fusebox near the battery for 10 seconds or more (depending on ambient temperature), with the ignition switch OFF. Removing the fuse is preferable as it is easier and will not reset the clock, alarm etc.
If the code(s) is(are) not cleared, then it(they) will appear with any new code(s) if a malfunction occurs in the future. Obviously this is not a good thing as the new fault cannot then be identified easily.
After clearing the code(s), the vehicle can be road tested and then the diagnostic system checked to make sure the system now reports code 1 (normal).
Introduction
- These conditions need to be true:
- Battery voltage above 11 volts.
- Throttle valve fully closed (throttle position sensor IDL points closed).
- Transmission set to neutral.
- Accessory switches off.
- Engine at normal operating temperature.
- Turn the ignition switch to ON but do not start the engine.
- Using an insulated wire with each end stripped, short terminals T and E1 of the diagnostics connector (see figure 1, right).
Diagnostic Codes
- Pressure sensor circuit.
- Pressure sensor.
- ECU.
- Ignition circuit (IGf ECU connection).
- Igniter.
- ECU.
- Coolant temperature sensor circuit.
- Coolant temperature sensor.
- ECU.
- Distributor circuit.
- Distributor.
- Starter signal circuit.
- ECU.
- Throttle position sensor circuit.
- Throttle position sensor.
- ECU.
- Air thermo sensor circuit.
- Air thermo sensor.
- ECU.
- Vehicle speed sensor circuit.
- Vehicle speed sensor.
- ECU.
- Main relay circuit.
- IG switch circuit (starter).
- IG switch.
- ECU.
- The vehicle has been push-started.
- Air conditioning switch circuit.
- Air conditioning switch.
- ECU.
